muttley600
Banned
I've replaced a lot of them with normal nuts yes.. The reason is that they end up getting gunky and don't work. You can't adjust the string height satisfactorily and they are pretty much a complex solution to a simple problem. Add to that that if you use strings heavier than 10's you need a different unit most times. My motto with the guitars over the years has become keep it simple.
To replace you need to remove the first fret and piece in a new f'b section to the correct nut slot and refinish. Not a massive job but you'd need to be confident to do it. I have replaced more than I have been asked to fit.
Oh and the Fender LSR are far superior to the Wilkinson models from the ones I've seen. I wouldn't have either on my guitars.
