Robertobly
Hello I'm hoping you can help me with a few questions as me and a few pals are planning on setting up our own studio & would like to be able to record at near highest fidelity possible as we're after a real, professional and classic sound e.g. Early Dylan/Nick Drake. Here goes...
1) Using a 2 track tape recorder to record not only a solo singer/songwriter but also a small band:
Now though I understand recording live to 2-track is quite possible via the stereo out of a mixer (by using a load of mics to pick everything up), i'd prefer to have more control over the tracks so my idea is to:-
Step1 - Record drums via 2-4 mics through a mixer into the 2 track recorder before sending to a DAW via a 2 channel high-end AD converter.
Step2 - Record bass/guitar, whilst monitoring the drum track(s) before sending it to DAW via AD & syncing up with drums
Step3 - Then record vocals, whilst monitoring the rest & syncing up accordingly
(repeating the process for any lead instruments we fancy lobbing on)
Now are there any technical problems that anyone can envisage with doing things this way other than the obvious laboriousness of recording everything separately? Could recording this way immediately reduce the 'realness'(for want of a better term)/quality/fidelity that I'm looking for? Is there something I'm fundamentally missing that would serve to completely undermine this process?
2) Fidelity:
Secondly, could someone please describe to me what is the fidelity gulf between a 1/2" 4-track, which in theory is 1/8" per track & 1/2" 2-track/1" 4-track, which in theory is 1/4" per track? Would you go as far as to say that it's the difference between very high quality recordings & semiprofessional for instance? At present I neither own or know of any specific recordings that used each of these set ups so at present I'm completely in the dark to whether one is really any better than the other. Any help/comments appreciated on this...
Similarly, is the difference between 15 & 30ips equally noticeable? I know some people who favour 15 and others 30 and without hearing recordings, I'm ignorant to the difference. I've read that only classical or more acoustic recordings really require 30 ips but obviously I'm not going to purchase a machine on mere hearsay so need to know. Should a machine running at 7 1/2ips even be a consideration?
3) Mastering:
Thirdly, with regards to mastering, I've thought of a few ways that it could be done and I would value some other folks' opinions as to the benefits and drawbacks of each.
My first idea was to record to tape and then mix/master on comp to cd/mp3. This seems the easiest (& at this moment the most preferred) method but i'm worried that the clarity and 'tapyness' of the original recording will be lost if I don't choose to master on a 2-track stereo tape machine beforehand?
Also after mastering on the computer, is there a way that from this I could transfer the recording onto vinyl if so desired at a later stage (if there was demand for it to be listened to this way)? I appreciate that if going vinyl, keeping the whole thing analogue would be the most beneficial thing but rather than necessity, releasing vinyl will be more of a luxury as unfortunately, most listen to mp3s/cds so we know we're going to have to compromise in order to reach folk with the music.
Perhaps it would be better to record to tape before mixing it on the computer and then sending it back out to be mastered on a stereo tape machine? I simply have no idea about this and again would sincerely appreciate any advice/opinion. I appreciate this may sound a little ludicrous as you may think why not just master to tape in the first place but we can't afford/get hold of/maintain a large multi-track recorder and we are exploring ways in which we could still keep control of as many individual tracks as possible without compromising the fidelity of the recording- as to sound professional & clear as originally stated.
I hope this description of my predicament is not too jumbled and that someone out there is able to offer me some sound and informed advice.
Kind regards,
Robert Blythin
2) Fidelity:
3) Mastering:
Kind regards,
Robert Blythin
