well to be honest i would need a tape recorder with 3¾ ips and 7½ ips because i have old tapes from my family witch some used 4 track recording. but i would also like to record my band. so if you have any recommendations that would be great, i really want to get into analog recording
THANKS!!!
There is nothing wrong with recording at 7 1/2ips. More important is that the tape deck works well, heads are good, that you're using good tape for which the recorder is setup and that you actually have good talent and know how to record properly - the technique factor.
You say you're recording a band... all in one live take or are there overdubs and / or you want to have many tracks for many instruments? This is important for the recommendation.
If the band is recorded live, to stereo or mono, then a simple open reel deck is cool like this:
http://toronto.en.craigslist.ca/tor/ele/1893937655.html
Has glass heads (they don't wear) and 3 most popular speeds, incl 15ips, using economy 1/4" tape and, I believe, is direct drive (no belts to change). Seller is willing to negotiate. This is the safest bet (if looking for a good deck to record a band live to mono or stereo, simplest way to get into proper analogue). A mixer would be nice, helpful but not really required for you can just plug in two mics. If you want one tho, to expand your sound, there's one here:
http://toronto.en.craigslist.ca/tor/msg/1886656556.html (good mixer).
If you're looking for overdubs and / or the ability to record each instrument on each own track then you need a multi-track recorder, sky is the limit. There is a Tascam 38 and mixer for sale on craigslist, in the Toronto area
http://toronto.en.craigslist.ca/tor/msg/1860810057.html but then you run into more costs for tape, having to gauge if the heads are good and generally more know how on what to test and most important, what you need. A mixer is required for multitracks.
If you require even more tracks then an MS-16 would be in order. Our long time friend on this forum Jeff (The Ghost of FM) has a nice one for sale (also LOCAL to you). I think a customary 10% OFF will be in order.
