Help
  • Thread starter Thread starter acaraballo06
A
acaraballo06
I need printable step by step instructions on how to burn cds.
What program are you using?
Here's a general process-
1. Stick a blank CD-R or DVD-R in your writable drive.
2. Open your burning software
3. Select what kind of CD you want to burn(Data is for files, such as session documents/Audio is for audio cds that you can play in your CD player/and Copy will allow you to make an exact copy of another CD if you have two drives)
4. Drag in the files or select the files you wish to burn in their browser
5. Double check to make sure that is what you want to burn.
6. Hit burn (some have a record button instead)
7. When the CD is done, you're golden.
How about -
1) Open the manual for the software you're using and
2) Follow it.
At the very least, we pretty much need to know everything in the "burn" chain to even hazard a guess.
Check on your software toolbar for "help," locate the section which is about burning CDs, click "print this page." If that dosent work, try http://www.tweakheadz.com/guide.htm and if that dosen't help...ask Light, if he don't know then nobody does.
O
Replies
5
Views
1K
rob aylestone
rob aylestone
TieDyedDevil
Replies
0
Views
240
TieDyedDevil
TieDyedDevil
M
Replies
0
Views
801
Martin J
M
