Help
  • Thread starter Thread starter AnolaMatt
A
AnolaMatt
OK, so I just hooked my delta 44 up to my computer and it is up and running.
My problem is...
When I plug my talk into the mic, this is what it looks like
http://www.anolasrecovery.com/delta.JPG
It only comes up on the left side.
What do I do to fix it?
You are plugging what where?
If it is a mono mic plugged into a stereo input .... you will only see it on one channel.
Which really isn't a problem, as most DAW software allows for mono tracks that can then be panned via the DAW's mixer.
Yep, thats how it SHOULD look. You have 4 seperate mono channels on the 44. You are using input #1.
H2H
yeap i agree.....i dont know what software your using but you can change the inputs in software to read the 1 2 3 and 4 inputs seperately....in your software if you put it on a mono input then it will come through both speakers as mono. nothing major there
