D
dlindsay
Hey! This has probably been covered to some extent, but I am hard headed and lazy, so bear with me!
I have Cubase SX3, pc based. I am using an EMU-1820m interface. I have a "generic" cheapy midi controller with only a midi out. (it is an MK something or other).
When I set up a midi track I can not get my VST to sound while using my controller.
I see there is midi activity when I press a key.
I have "all midi devices" set as input and "any" channel. I have the output set as the VST. I have "midi-thru" activated. I have "record enabled".
What am I not doing right?
When I click on the virtual device, say a synth, I get a sound... it is just that my external midi controller will not trigger the sound.
I will greatly appreciate any advice offered!
Thanks,
Don Lindsay
dlindsay@pineland.net
Thanks,
Don Lindsay
Set the channel to the proper channel, and make sure your VSTi is also set to receive on that channel (usually setting the cubase MIDI channel to 1 is a good choice, as most synths are either set to omni or default to 1). And instead of having "all midi devices" select the correct one. Cubase doesn't like it when people are being sloppy with it.
