R
RonE
I'm hoping someone has some suggestions about which sound cards are recommended. I have a fairly new HP Pro3500 64-bit multi-core PC running Win7 Pro 64-bit, with 8Gb of ram and a separate 7200RPM HDD for audio capture. I'm not new to this PC recording thing; but my last computer was running WinXP and had standard PCI slots, and I was using an M-Audio 2496 which worked very well.
So...
My first attempts used the on-board RealTek audio chipset, which was fine for frequency response; but had a noise floor that was only down about 40 dB. Not acceptable.
First I tried an ASUS Xonar DX, which might have worked (but probably not) if it hadn't been for a requirement of a specific power supply connector which my PC did not have, so I replaced it with an ASUS Xonar DSX, which has slightly lower SNR than the DX. BUT (and this pisses me off!), there's a delay of about 100mS in the audio line in, which renders the interface useless for any meaningful recording purposes. A quick search of the Asus support forum revealed several other inquiries into this issue, and the response from ASUS was that there wasn't anything they could do. The Xonar (and presumably other ASUS sound cards) all did the same thing and they had no plans to address it!
There are a lot of other choices; but can anyone here recommend a PCI Express (PCIe) audio card they KNOW doesn't have this little 'flaw'? I've used Creative Labs stuff in the past; but I don't know about any of their newer stuff.
TIA!
So...
TIA!
