E
erreece
Hello. I'm building a new home studio and need some advice about preamps and audio interfaces. Here's my situation: I have five Bellari MP105 preamps from a home studio I had in the early 2000s and will be recording on a Macbook Pro with either Studio One or Garageband DAW. I'm just one guy and will only need to record one track at a time. I do the drum machine, guitars, bass, synth, vocals myself, so there's no need for multiple inputs/channels. I've been looking at USB audio interfaces, but since I have all these Bellaris it seems like I don't need an interface with preamps, unless modern interfaces come with better preamps than what I have. How should I take advantage of all these preamps (chains and what not) and what kind of interface would you recommend? I don't have much money. Looking to spend less than $200. What would be the ideal setup with the equipment I have?
Thanks,
Elliott
Thanks,
Elliott
. If you get one, make sure it is a V2 in the Scarlett line. (According to Focusrite, the Saffire and Scarlett interfaces all have the same mic preamps, it's only the taper on the GAIN control which is different in the V2s, but it does make them easier to use for most.)
