what are those two things that look like dilapidated boobies on the lower left?
I'd set up with my desk on the left...back to the long part of the room and trap the corners to start.
what instruments will be played in there?
Sorry, those are doors- same with on the left.what are those two things that look like dilapidated boobies on the lower left?
Mostly guitar and possibly drums.
Thanks for the advice. I can't really trap the corners where the closets are because (I forgot to draw them in the picture) the closet doors open into the room. While this cause a big issue?Exactly. Then do all the basics (my standard list):
Your head should be placed 38% of the way into the room, centered between the left and right walls
Your head should also be located at the tip of an equilateral triangle with your speakers. Start at a 5’ width and go from there.
Use at least 4” bass trapping in all the corners, floor to ceiling if possible.
Use 4” or 6” bass traps on the back wall; the thicker the better basically.
Use 4” panels behind the speakers on the front wall
The reflection points to the right, left and above your head can be treated with either 2” or 4” panels. I prefer 4” panels personally; you can never really overdo bass trapping.
You can use diffusion on the right and left walls near the rear of the room, between your bass traps on the back wall or on the ceiling to the rear of your ceiling panels.
Frank
