killthepixelnow
Do it right or dont do it
Hello guys, I've been using a pedal-board form a time now and although I like the way is set, I have some concerns that the order of the pedals might be hurting my signal. As you will see in the diagram below, I split my signal in order to use two amps instead of one. The issue is that from time to time, one signal goes completely off. I suspect the one using the Noise Gate (blue one in the diagram) is the culprit. Do you think is bad to use two noise suppressors? Any suggestions of what might I do?
Notes:
[1] I basically use the EQ as a boost for solos.
[2] The Delay, the Reverb and the Maximizer will sound better via the send and return of the amp, but this is how I have set it for now.
[3] I'm using high quality Oval and Mogami pedal couplers, so don't blame them.
Thanks in advance!
Notes:
Thanks in advance!
