Regedit is your system registry editor you may need to add the directory that contains it to your path, howver, this is usually set up at installation time., so if it is not in your path, you have hosed something.kaibil1 said:i just get my new audi/midi interface that came with free cubase le but when im installing it almos at the end of instalation gives me this message:::regedit is not a valid windows application:::what a heck is that?
thanks in advance
fraserhutch said:Regedit is your system registry editor you may need to add the directory that contains it to your path, howver, this is usually set up at installation time., so if it is not in your path, you have hosed something.
from your start menu's run command dialog type regedit.
