H
HomeRec
I recently purchased an Aardvark Direct Pro 24/96 card/box combo, which came with Cakewalk Pro Audio 9. I have the Aardvark card and software mixer installed and running, as well as Pro Audio 9.
However, recently I haven't been able to get past one track without having it "pop" and lose sync when recording another track. I'm running all of this on an older system, so my thought is that that's the problem. However, the stats on the system exceed the minimums for both the card and the software. I plan to contact Aardvark tech support as well, but I wanted to find out if anyone knew of any settings tweaks I could try. Thanks.
SYSTEM SPECS
Pentium II 333MHz
8GB generic hard drive (unsure of speed)
320MB of RAM (66MHz)
Windows 98 (not Second Edition)
MINIMUM REQUIREMENTS
Pro Audio - 233MHz (200?) Pentium, 64MB RAM (req's no longer available)
Aardvark - 133 MHz w/ Win 95/98; 64 MB RAM
SYSTEM SPECS
Pentium II 333MHz
). Chances are, I will end up with 98SE (or 2000, assuming Aardvark's drivers work well) when I buy a new system.
