G
gareth finland
Hi ,
I have a vf16 and i am having trouble hooking up and using the aux send loop.
I have connected the y cable so the stero jack is plugged into the aux send jack on the back panel. Then I connected one of the mono jacks to the input on my zoom effects unit and the other to the out.
I selected both the aux1 and aux2 of the pre recorded track and put them to 99 but the original sound stays the same.
I have tried swapping the mono cables over but still no joy.
I know the effects unit is getting a signal as i have listened to it with headphones.
Am I missing something or what?
Thanks
Gareth
Thanks
Gareth
. A "Y" connector with one stereo plug and two mono plugs sends aux 1 to one mono and aux 2 to the other mono. Reference your manual to see how the TRS (stereo) plug is set up. What you may need to do is one of two things:
. A "Y" connector with a TRS plug and two mono plugs is used to send AND return a signal to and from a processor. This will work with an fx unit but is perfect when you want to use a dynamics processor (compressor, EQ) for a single channel. The insert will work for only the single channel (7 or 8) being used, though both channels can go into a stereo processor at the same time.
