B
Bassman2003
Hello,
I have my own video/photo/audio business and am looking at my audio setup.
I have had a Firewire 410 and a pair of Wharfdale nearfields for quite a few years. I am getting some distortion in the mid's to upper mid's which I think is coming from the Firewire 410 as my headphones seems to be having the same sound.
So I am investigating a different audio interface.
Here is my usage requirements:
1) Mainly this is to be used to playback and mix audio I have recorded through my video work. So I would like great sounding audio for playback. - Is there much difference in playback sound quality between today's digital interfaces?
2) From time to time I do record a voiceover track, so a high quality pre-amp would be needed as well.
Would I be better served separating my "sound card" and my recording preamp?
3) USB or Firewire? In the past it seemed firewire was the clear choice, but systems are so quick these days, does it matter? Is there one connect that seems to offer higher quality products? Like all of the professional gear uses firewire etc...
I don't want to set a budget to let the quality level determine my choices.
I will be using Windows 7 and my system will soon be an i7 setup with 12gb of ram.
I also need the card to have analogue inputs as my video output card sends audio out that needs to be put back into the system.
Thanks for your input!
