Farview said:The biggest mistake made is tuning the drums too high. The bottom head needs to be tuned higher than the top (just a bit, 2 or 3 semitones). What metal guys have been doing forever is tuning the bottom head to the note you want, and tuning the top head almost slack (don't worry about a wrinkle) Just tight enough that the stick will still bounce off. If you get ring that way, your bottom heads are our of adjustment (the tension is not equal between the lugs)
ez_willis said:Hey Farview, are you saying that when a drum is tuned properly, a little wrinkle is roughly where the tension should be? If so, does that apply to all drums, including the snare? I've been fighting drum sounds since buying a kit for my home studio, but I've been throttling down pretty good on them lugs.
RecordingIdiot said:If you try it on a Pearl Export it will sound great....what about pearl forum? is there different tuning techniques for cheaper drums? my toms sound decent but im getting a god awful ring in my snare and floor tom, causing feedback when im mic'ed. any suggestions?
