slip
I just recently started working with cool edit pro 2 to try some music production, I have spent much more time doing live recording with protools and am actually much more comfortable in that enviornment but I would like to learn this new tool.
Here is my problem:
When I attempt to manipulate an audio file, I get audible clicks at the end of the track. If I try to play a range of a prerecorded audio file i get a click at the end of my selected range. If i move the range the click moves. If I trim the click off the end I get a new click.
I thought perhaps it was a problem with my sound card on this box (audigy 2 with the open al beta driver) but I noticed when i tried to splice on a measure to the end of a sample I was working on that not only did the click at the previous "end of the track" remain but there was also a click at the new end. It also appears as if the waveform is being altered at the trim/splice points and dosent reflect a true cut at my intended cue position
I have tried manipulating files with the "Smooth Delete and Cut Boundaries" and the "Smooth all edit boundaries by crossfading" on the settigs>data> tab both on and off and all combos of the two and I still get clicks all over the place.
Please help! Anbody have any ideas?
Here is my problem:
