Hi guys, I really need some help here...Does anyone know what causes a Win2K system to just freeze up all the time? Read my scenario for the possible causes and the possible causes I've already eliminated.
I had a rock-solid DAW that I built myself and worked with for 6 months without any problems. I then packed it up and drove it across country, and since I got back to New York it's been nothing but problems. The first thing I did after I unpacked it was take off the heatsink and install a larger and quieter fan on it. However, when I booted up the computer I got a blank screen...I took it into a repair shop and they said the CPU was dead, despite not having any visible signs of damage on it. I'm not sure if I caused this with the heatsink/fan replacement or if it was caused by being bumped on the road although I did pack it fairly well. In either case, I had the store put in a new CPU as well as put the heatsink on it to make sure it was done right. Voila, now the computer would work, however it freezes all the time, no matter what program I'm in. Even if I'm not in a program, just browsing through a folder it will sometimes do it.
I did install the latest drivers for my Delta, Midisport, etc. as soon as I got the computer working again, but I doubt those could have caused these problems. I've reformatted my OS hard drive and reinstalled Windows because I thought it might be a software/driver issue, but even with no software on my computer but Windows it still freezes. I've removed ACPI and done all the tweaks I could think of but none worked, it really seems like a hardware problem. It does not actually crash (no blue screen, maybe that's because of Win2K) but just freezes there - no mouse movement, etc. Could this be caused by the new CPU? Maybe the video card or mobo was also damaged in transit? My question is what piece of hardware could cause a computer to work, but then freeze up after a few minutes. I have noticed that certain things such as playing back Cubase projects or working in Wavelab would cause it to freeze a little quicker than if I'm just browsing through a help file or something, however even help files will make it freeze. Anyway, here's my setup, if anyone even has any guesses that would be appreciated:
Asus A7M266 mobo, AMD XP 1900, Windows 2000, 512 MB Micron DDR RAM, 2 40 gig 7200 RPM Maxtor HD's, Maxtor G450 vid, Plextor CDRW, Delta 66/Omni Studio, Midisport 2x2, Enermax 350W PSU.
By the way, the new heatsink/fan is cooling adequately (highest temps go to 59 C, however my mobo supposedly reads 10 C too high) so I don't think that is causing the problem, in case any astute readers might have suggested that. Thanks again for any help!
Michael
Michael
