allandall said:
Also posted in The Rack section:
So I've got a Mackie CR1604 board. I'm running my behringer stereo compressor through it. I've got the board running the aux outs to the compressor, but when I run them through the aux returns, it won't record with compression. I can hear it compressing, and can controll the level throught the aux return controls, but it won't go on to the mix. so right now i've got them returned through my last two tracks, which works, but isn't what I want to do. I want them to come back through the tracks I have them assigned to. please help!
Jonah
Firstly, you aren't running compressor "through" your mixer, you're running something from your mix through your compressor. So if the problem is getting that effected "something" back into the mixer you have options.
I believe
the cr1604 has inserts on every channel. If you want to compress the bass track say; use a trs to 2 ts cable. This is a stereo (TRS) 1/4" jack on one end, to two mono (TS) 1/4" jacks on the other end(s).
Tip is send ring is return. This means that when you plus the stereo (TRS) jack into the bass channel insert, the TIP portion of the cable carries the signal. Plug the end marked "tip" into the input on your compressor, and the end marked "ring" into the output on the compressor.
You have created a loop. Part of the bass signal is sent (i can't remember if it's pre fader or post but i think mackie defaults to pre fader: this means that the signal is tapped BEFORE the eq pan and level fader) to the compressor. You modify the signal by controlling the compressor, then the signal leaves the compressor and returns to the channel. Now you apply eq, pan and level.
If you are attempting to compress the entire L/R mix: Use the exact same procedure above but use the Main Insert jack on the back of the mixer (i think it has one, it damn well better).
If you want to compress a group of channels, then it's tricky. I don't believe on the 16 channel boards, mackie built in group inserts. I think those are features on the 8 buss consoles. But, if you group say 4 vocal tracks to group 1, take a 1/4" cable and connect it to compressor input. Connect another 1/4" patch to compressor output, and return the signal to an empty line input channel on your mixer. Granted this will be mono, and not a true inline effect.
You would then be advised to remove the vocal tracks from the l/r buss, remove the group from the l/r buss, and only monitor the signal returning to the mixer from the compressor.
I hope that helps a little.
rereading your original post. To do it your way, you would need to assign the aux return to the l/r buss to hear it in the mix.
