Help Setting Up Studio
  • Thread starter Thread starter A1MixMan
A
A1MixMan
What's up.
I am in need of advice in setting up my equipment so it works well with Sonar 3.
Here's what I have:
Sonar 3 Producer Edition
Delta 1010 soundcard
Mackie 1202VLZ Pro mixer
Neumann TLM103 Mic
Mackie HR824 speakers
How I want it setup:
I would like to use my mixer mainly as a preamp for my mic, sending that into the soundcard. Then I would like to send the soundcard output back into the mixer so I can control the volume of my speakers with the mixer.
I also need to have input monitoring setup without creating a feedback loop.
I'm still relatively new to all this, and all of these inputs and settings have my head spinning.
Thanks for your time,
A1MixMan
A1MixMan said:
What's up.
Here's what I have:
Neumann TLM103 Mic
Your signal chain could be,
Mic -> Mackie mic Pre 1 via XLR cable -> Main out L -> Delta 1010 input 1 -> COMPUTER -> Delta 1010 output 1 -> Mackie line in 2.
When tracking with a mic, turn off your monitors and use headphones. That should eliminate feedback loop. Input monitoring is a setting in Sonar, which you should turn on if you wanna use it.
hope this helped more than my first post.:)
