J
juzcook
Hi, I've just started building a small home studio with pretty decent equipment. I'm using a Eurorack UB-2442 12 Channel Mixer running through an iMic into an Apple G4 iBook running Pro Tools 5.0 in OS 9.2.2.
I'm monitoring sound after it's been recorded with 2x 7" Speakers through an amplifier, where the humming is only slightly heard. However when listening to the recording in iTunes or from a CD the hum is much more evident.
When recording, I'm only using a standard vocal mic approx. 10-20 cm from the Guitar amplifier's (60 watt) speaker at just above half volume. There is very little EQ being used on the mixer but that doesn't stop the humming. The Guitar amplifier itself has been readjusted many times (ie. Reducing Bass, Volume, Presence, Mids etc) and the hum persists. I'm looking for a cheap way of solving this problem, or the expensive way if it's the only way.
The other problem is recording with the sound being input a split second after it's heard causing a delay and timing errors which must then be corrected manually. When recording over the top of multiple tracks I must mute the tracks being recorded in order to keep time. Remember I'm using Mac OS 9.2.2 for all of this because OS X brings me an error when using Pro Tools LE 6.0 saying the timing is out and I should reset my clock settings.
If anyone can help me solve any or all of these issues, it would be greatly appreciated.
