Help Please - Recording Troubles?? (Lexicon Alpha / Cubase LE 4)
  • Thread starter Thread starter pac_112
P
pac_112
Hi All,
I hope that you are well.
My problem is simply getting sound to record / play back through both speakers, after I mixdown a track, the track only plays through the right speaker?
Just so that you know my setup I have is as follows:
Rode NT1-A (Condensor Mic)
Going into a ART TUBE MP Preamp / Phantom Power Source
Connected to my Lexion Con Alpha
Connected to my PC Via USB
I have head phones plugged into the LEXICON and I can hear sound through both headset speakers.
In device Setup I have the VST Audio System set to “ALPHA ASIO”
I have no problems recording/multi tracking etc
When I “Add Audio” if I add as a stereo configuration, it records perfectly, however only plays back through the right speaker.
(If I add as mono nothing records, when I hit the record button)
If any one is familiar with this hardware / software pleaseshare some insight as to what you belive I am doing wrong?
Any help that can provided Is greatly appreciated
Cheers
Hi, I had that problem when i first started recording, please check the following things:
Go to:
1) Devices --> VST Connections
2) Go to "Outputs" tab and check the "Left/Right" device port... it should say something like Lexicon Alpha 1/2 with the Left and Right... I think that your Left port says "No Connected".
Good Luck
I've got the same problem. But in my Devices - VST Connections I have a Stereo 1 Bus with Left port connected to In1 and Right to In2.
It seems that my microphone is connected to In1 and my Keyboard to In2.
Mono doesn't work at all.
