siteslinger
Okay, so I've got a 24-track mixer with 8 subgroups, going into an 8-track tape machine. Each subgroup has an XLR output, and a 1/4" insert patch. I couldn't find XLR-to-RCA cables, so to output to the recorder, I've been using a 1/4"-to-RCA snake, with each 1/4" male plug sticking halfway out of the inserts on each subgroup. It has worked but since it's an insert, the subgroup fader is bypassed.
Now, I got one XLR-to-RCA adaptor, and nothing seems to be coming out of the subgroup XLR output. I've got the subgroup selected on the input channel, and I know the signal reaches the subgroup because it goes out the insert if something is plugged into it, and I can hear it with the PFL. But no matter what, I can't get the VUs on the recorder to even flicker when using the XLR outputs. I've tried every subgroup, and every input channel on the recorder. I've also checked the adaptor, and it passes signal fine. I've also routed the XLR output of the subgroups into another open channel, and get nothing.
What's going on here? Is XLR-to-RCA not possible or something? What am I doing wrong, any ideas?
Thanks!
Thanks!
