Fat_Satchel
I suffer Narcoleptic Rage
First off...tried to post this over at Flavs site...told to make an account, made an account, logged in...went to start my threed and get told I cant cus Im not logged in....go figure...
Anyways...
Im finally trying to get into some automation but so far not so good. I followed the help file instruction...
Example...Aux send volume
Select what parts you want to work with and click "X" (delete symbol...function is silence selection) to set the volume to 0...ok that works...it moves the envelope line to the bottom edge of each wav file...looks good so far. Then I zoom in and add a couple nodes and move a part of the envelope line back up to the centerline of the wav file...click the P and the R on the mixer and hit play....At the part, I see the fader go from INF up to about -20 or so...huh?? Wouldnt the centerline be -0??
So I move the nodes I added all the way to the top edge of the wav file and press play...fader moves up to about -15 or so...WTF??
What am I doing wrong here?
Anyways...
