Hey,
I'm about to get myself a new USB Audio Interface.
My 3 top choices are as follows:
The software which comes with the interface is not important. I will be using Cubase anyway.
Thank you for taking part in this!
- Roland UA-55 Quad-Capture
USB 2.0 Audio Interface 24-bit/192 kHz, Two combo XLR/TRS inputs with premium mic preamps (VS thomann Preamps), two TRS outputs, coaxial I/O, headphone out, and MIDI I/O, Graphical Control Panel software provides fast, intuitive control of the VS Preamps, Phantom power, ground lift, and Hi-Z switches, One-click AUTO-SENS function intelligently sets optimal input levels for the preamps, Extreme low-latency thomann VS Streaming driver, Low-noise, wide-range power supply, Compact with durable aluminum body and Direct Box functionality, Bundled with Cakewalk SONAR X1 LE (Windows PC Software), Power Supply: USB, Abmaße: 185 x 134 x 44 mm, Gewicht: 570 gr.
- Native Instruments Komplete Audio 6
compact USB2 audio interface (24-bit/96kHz) 4 balanced analog Inputs: 2 x Mic/Line/Instrument (XLR thomann Combo); 2 x Line (1/4" TRS), 4 balanced analog Outputs (1/4" TRS), S/PDIF I/O, MIDI I/O, Headphone Out, Direct Monitoring, 48V Phantom Power, includes Cubase LE6, Komplete Elements, Traktor LE 2 Software
- Focusrite Scarlett 2i4
USB 2.0 Audio Interface 24 Bit/96 kHz, 2 Inputs and 4 Outputs, 2x XLR/TR 1/4" Mic/Line thomann Combo-Inputs, 2x Line-Outputs 1/4" TRS balanced + 2x RCA Line-Out unbalanced, Headphone-Out, MIDI I/O, +48 Phantom Power, -10dB Pad, incl. Scarlett-VST-/AU-Plug-in-Suite: Compressor, Reverb, Gate and Equalizer, Ableton Live Lite 8
