Hi, i'm looking to buy another mic for stereo - micing acoustic guitar. My only condenser is the ADK A-51 (specs below).
I've no idea what to look for to ensure that the stereo sound is not mismatched, so any input would be kindly recieved. I have approx £100 to spend new or second hand.
Cheers, Mark
ADK A-51 Standard Specifications
TYPE: True Condenser Pressure Gradient Microphone
CAPSULE: 1" Diameter, Low Micron, Gold Vapor-Deposited Gradient Design
ELECTRONICS: Low Noise Discrete FET
FREQUENCY RANGE: 20 Hz to 20 kHz
SENSITIVITY: 15 mV/pA 9-36.5 = 1 V/pA
EQUIVALENT NOISE LEVEL: (A-Weighted per IEC 286-4) < 17db Typical
MAXIMUM SPL FOR THD : <0.5% (1 kHz) 130 dB
SWITCHABLE LOW FREQUENCY CUT-OFF : 100 Hz (Internal Switch)
CONSTRUCTION: Heavy Duty Aircraft Grade Machined Brass with Durable Scratch Resistant Anodized Finish
WEIGHT: 470 grams / 1.03 lbs.
DIMENSIONS: 50 x 190 mm / 2" x 7.5"
Cheers, Mark
