C
Cheeky Monkey
Hi. I'm running Cubase SX 2 on an AMD PC (512mb ram, 2.4ghz) with Windows XP Professional. I have an Asus A7V8X-X motherboard. The last couple of times I booted-up, the BIOS setup screen opened up right away prompting me to select a CPU speed from the menu (options are: Manual, 1100mhz, 1467mhz, 1833mhz, 2200mhz) and the help text said that the CPU must be set higher than 333mhz. So, the first time this happened, I think I chose 1467, logged-in, worked in Cubase, shutdown when finished. Tonight when I booted-up the BIOS setup screen opened again. Figuring that 1467 didn't solve it, this time I chose 2200 and I started having all kinds of problems -- Windows wouldn't open -- in Safe Mode or otherwise. After many hard boots, the BIOS setup screen finally opened on it's own again, and when I selected 1100, the help text box tells me that I have to choose the setting appropriate for my CPU. According to my Asus motherboard user manual, my CPU specs state: Socket A for AMD Barton/Thoroughbred/Athlon/Duron 2.25+ GHz CPU.
I'm not very good at troubleshooting this kind of problem. Can someone please advise which CPU setting I should choose? If my specs say 2.25 GHz, it seems to me that the 2200MHz option should be the closest, though it's way less. But like I said, when I tried that selection, I had real problems. I appreciate any advice. Thanks.
p.s. When I tried to access the BIOS setup on my own at boot-up by pressing F2, I can't seem to access it. Any suggestions as to why not?
