B
Blues
I have a AMD 2.01 with a VIA KT333 chipset
On and off for 5 months ive been getting this error message in the bootup screen
WARNING! CPU Clock Failure
Reset host CPU Ratio
i took it to the tech who originally built the PC for me, he reset the jumpers then re tweeked the BIOS options to optimize it's performance for audio (The same settings as before). I take it back home and I still get the same message ..this time only once.
Whats more....I was making a song with only 5 audio tracks running with 2 or 3 plug in effects each. The VST performance reader said my CPU pushing at 90% percent! WTF?!?
My tech said he tested and ran Cubase when he originally built the system and said that it was ruuning 24 tracks with heavy effects on it just fine. Also said the 32 audio tracks with light effects should be fine too. What's going on?
Saving songs is taking forever whereas before..it would save and load up songs in the blick of an eye! I check out the cpu performance in the task manager window, with no progams running..just the desktop, and the cpu performace is jumping from 1% to 11% to 14% to 33%....when i load up Cubase..it then jumps up from 34% to 68% to 93% to 100% back n forth....there's no consistency in it's behavoir.
IS my cpu damaged? Is it a buggy chipset? should I reformat and start fresh or go all out and spend more money that i cant afford on an all new motherboard?
HELP!!! I'm a musician not a damn Tech, man! I dont have time for this hassle!
lame as that is, heh, go to the cpu ratio setup in the bios and set the multi to what ever your cpu mhz is suppose to be, 12 - 12.5 etc etc, that will fix the issue but you'll see it again, for help go to
