Help! Buzzing monitor (AlesisM1)
  • Thread starter Thread starter jake-owa
jake-owa
jake-owa
Banned
ARRRGH!. I've done everything.
I have the Alesis passive M1s powered by an Alesis RA100 coming out of my Roland VM3100. The problem is one side buzzes at certain frequencies, especially on bass notes. I've been using them for three years with no problems and now this is about to drive me nuts. I've done all the typical troubleshooting, swicthed amp channels, amps, changed drivers and tweeters around and still the D and G buzz the hell out of my left monitor.
It sounds like something is buzzing on my desk or inside the speaker but it's not, it is the speaker, I've had the damn thing apart ten times, glued everything into the cabinet...ect.. The sound decreases when I pick the speaker up but it is still audible compared to the right channel.
Please...do you know what this is?
Help...I'm going insane.:( :mad: :(
C'mon someone....I've got them apart.
Is there anything I can do?
Has anyone had this paperey, frequency specific buzz.
Is everyone partying in the cave?:eek:
Sounds like a blown driver to me........... when you fry a driver, it doesn't necessarily "flap" all the time -- I've had speakers go "partially" where only certain low freqs make a very obvious "papery flutter" on the woofer....
Replace the driver and you should be good to go...........
Blue Bear, it's not the driver because I've switched the drivers between cabinets and the same enclosure is making the noise.
The port tube inside is solid and nothing else seems loose.
:confused:
Well I reassembled the cabinet. This time I scraped all the old adhesive and placed a couple drops of Elmer's glue between assembled parts, zip tied some wires away from the porting tube.
It worked, sounds great now.
So no worries...thanks.:)
