Hey
I've got a Traynor tcx212 cabinet. It says its rated at 4 ohms (i have no idea if its per speaker but i assume its for the whole cab).
My amp however says 8 - 16 ohms. SHould i not use these together?! The cabinet says its wired 4ohms PARALLEL does this make a difference????
How can i get around all this. The cab also has a jack to daisy chain with another cab. If i did this would it even everything out? Or would it be better to get a Y cable for the amp output and run it parallel to two cabs? do i even NEED to cabs to solve this?
If i HAVE to rewire the inside of the cab what do i do.
as you can see i am LOOOOOOST
please someone help me
thanks
Col
ps. the speakers are celestion seventy 80's which im PRETTY sure are either 4 or 8 ohms. does that even matter since its all wired a certain way
pps. HELP!!
thanks
Col
pps. HELP!!
