loudnaybor
Don't give up so easily.
First off, that high flexibility wire CAN be soldered. It's a lot easier to do if you use a gob of flux before touching your solder to the connection. Don't rely on the stuff that comes in the core of the solder itself.
Second, if you have good joints ( solder joints ) there is absolutely NO reason why you can't get this to work.
Your asumptions on the color coding make sense and I would have assumed the same as you did, but that doesn't mean it's right. Do you have access to an Ohm Meter ?
[This message has been edited by loudnaybor (edited 11-12-1999).]
