J
James HE
a spoonfull weighs a ton
Mattman84 said:I'm on a pretty low budget, trying to keep this thing around the $100 mark, so some of these, while they would be awesome, are getting a little pricey for me.
I like the Behringer HA4700 and I think it's the one for me, with a few caveats...
I'm trying to work out a scenario where this will work in my setup. I do all monitoring from a Mackie 1402-VLZ Pro mixer. The main XLR outputs go to TRS lines fed into my monitors. I could use the 1/4" main outputs of the board to go into the amp, but there doesn't appear to be anyway to individually control the different outputs on the board. (correct me if I'm wrong). So, if I wanted to turn up the signal to the headphone amp, I'd also be turning up my monitors. Solutions to this problem would be to turn down my monitor volumes on the monitors themselves (which would get really old really quick...volume knobs on the back of each). Or, if there is a box I could run in between the board and the monitors that acts as an on/off switch that I could press, without degrading the signal. Anyone know of such a product?
The next option would be to run the output of the board through the headphone amp, and back out to the monitors. But there doesn't seem to be any way to control the output of the Behringer. So again, to turn down the monitors I would have to turn down the entire mix. Is there some sort of monitor mute or master out volume control function on the HA4700 that I'm not aware of?
My last idea would be to run out of an AUX send. I could use the AUX send 1 on my board into the headphone amp, and just determine the master mix by turning up the appropiate AUX knobs on the board. My only problem here is that the AUX sends on the board are mono. This isn't a huge deal, but stereo would be nice.
If anyone has any other suggestions on setup or solutions to the problems above, please let me know. Once I've got the setup of all of it laid out I'll go ahead and make my purchase.
Thanks everyone for all your help!
-Matt
I used to do it this way when I had a 1402 VLZ. Run the headphone amp out from the 3/4 alt outputs. Then you can switch from monitors to headphones, by simply selecting mains or 3/4 from the channel that your outs from your (soundcard?) are fed into. Now switching to the phones mutes the monitors. This works unless you want to have both the monitors and ohones going at the same time. If you need that go with the aux send.
