travelin travis
RAK said:10 characters needed.
whoops, my bad.
starsxandxslits said:yes, i was planning on splitting the stereo out. does an insert cable split a balanced stereo signal into two unbalanced mono signals...i mean i kinda get that different parts of the signal are carried on different legs of he cable, but my understanding of all that is pretty much crap.
RAK said:Why not just get an all male Y-Cable. Single TRS to dual TS. Also known as an Insert cable. That you don't need extra 1/4" cables to run from the splitter cable to the headphone amp.
Also stricly speaking, a headphone amp Input is looking for a line level signal, and you're talking about feeding it from the Tascams headphone out. I'm sure this will work, but it may be too hot.
Also, whenever you see two RCA inputs (usually red and white), that's always stereo analog. S/PDif (usually yellow) carries both channels over 1 connection. It's also called Coaxial, which is what you have on your Tascam.
starsxandxslits said:then how would this work?
TravisinFlorida said:The way it was explained to me, the signal will not be noticeably degraded unless you split it more than a few times. I've tried it and haven't had any issues. Assuming your headphone amp and monitors have balanced inputs, each y cable would have all trs 1/4" connections.
TravisinFlorida said:One more thing. I didn't have any problems when splitting a line signal between my devices but depending on your device's input impedances, you might have some issues. There are guys here that have built switching boxes and you might be better off asking them about this. My headphone amp has a monitor thru feature and my sound card has 4 stereo outputs so I don't need any kind of splitting or switching device there.
notCardio said:This isn't about the SG, I promise.
What kind of heapdphone amp do you have? I didn't know they made any with a monitor through.
RAK said:Or you could get two Y Cables (Male TRS to Dual Female TS cables). Plug each of the Male ends into the Main L&R of the Tascam, then you'd need 4 TS cables to run the signal to both your monitors and a headphone amp. That should work, but it's kind of messy.
notCardio said:any less of a signal path for the monitors than my going through the unaffected tape out of a home stereo?
TravisinFlorida said:Why drop the balanced signals to unblanced?
RAK said:If you plug a TRS to dual TS cable into each of the Main Outputs, then it should split the signal allowing you to send each Main Output to two locations (monitors and headphone amp).
Main L goes out the TRS line and is split, being sent out each TS end.
Main R goes out the TRS line and is split, being sent out each TS end.
At least I think it should work that way. The cable is just a cable, you can use it anyway you want. I suppose you could get a TRS to Dual TRS cable, but I'm not sure it really matters all that much, and the headphone amps 1/4" inputs are probably unbalanced anyway, but that's just a guess.
TravisinFlorida said:wait, are we talking about the tascam's headphone out or it's line outs?
c7sus said:I've never seen a balanced Y cable where all three connectors are balanced.
Yes, an insert cable will split a stereo signal into a pair of unbalanced mono signals. That is, if your TRS output is a stereo signal.
It's how I get from my Soundblaster into my patchbay or mixer.
