J
johnC
3630-shudder
I've used a 3630 without complaint, but have nothing to comapre it to. Keep in mind that any compressor will color the sound unless the sound source is ruler flat. A compressor will suppress any boosted frequencies in your e.q.s, which will appear to color the sound.
All compressors will amplify any ambient noise that may be on the signal especially if used as a limiter, especially during quiet passages. I had always thought that this was why it is so common for manufacturers to include a noise gate function with thier compressors.
One respondant complained of signal loss through the 3630. Be aware that the output levels on the 3630 are selectable between +4db and -10db (on each channel). If your gear is at +4 but the 3630 is set at -10 there will be signal loss, your fault not the units.
Maybe there are some bad units out there, but I've seen these units used in major studios.
Thanks!
