This is driving me nuts
I've finally got a replacement card for one I returned as faulty and it's just the same.
Can someone else who owns one of these cards please, please, please carry out a test to see if theirs has the fault too?
Here's a copy of the test procedure I've posted in the RMAA forum...
For those testing this card, I would ask if you could confirm a problem I 've come across with the cards s/pdif out channel. Fortunately, you do not have to connect any external device to to test for this condition.
I've found a problem with the s/pdif output of my Audiophile 192 card, this post is intended as a "heads up" to other owners in case mine isn't an isolated case. You may not have used the s/pdif output on yours yet or not often, and therefore might be blissfully unaware.
The Problem.
Playback over s/pdif is sometimes either silent or distorted but not every time. The fault only occurs when playback is started, never at some point during playback. The fault does not clear until playback has been stopped, it never corrects by itself during playback. The occurences are apparently random but fairly frequent.
The normal 1/2 channel that feeds the Main analog outputs is unaffected by this problem and always plays correctly, even if in use at the same time as the s/pdif channel while that is suffering the fault. The problem is entirely in the s/pdif out channel.
The actual physical s/pdif output of the card or the external device it is feeding, is not involved in causing the fault.
The fault may be heard using the cards Monitor outputs via the WavOut s/pdif faders in the Delta Control Panel monitor mixer tab - you don't have to connect anything to the cards s/pdif output RCA jack. However, if you did attach an external DAC to the s/pdif output, you would hear the same problem out of that.
The Test.
The ideal program to use for this is RightMark Audio Analyser.
It is a free download from...
http://audio.rightmark.org/download.shtml
Open RMAA and apply the following settings (all others should be ok left with the defaults)
Playback/Recording.
In the top dropdown, pick AP192 s/pdif
Underneath that, pick AP192 1/2
For the sample/rate and bit depth, pick easy ones like 16bit and 44.1Khz (not important).
Click on the "M" icon on your taskbar to open the cards Control Panel.
On the Monitor mixer tab, turn up and unmute (mute unchecked) the WavOut S/PDIF faders. Arrange to use the cards MON output jacks to feed your speakers/amp if you're not already.
In RMAA, click on the loopback test icon or start the input level setting function.
The program will now start playing a repeating "beep" sound, alternating between left and right channels. Ignore the fact that the Input Setting window warns that level is too low, we are not concerned wth it now. It is the fact that RMAA starts and stops to repeat the beep that makes it so good for showing up the fault. Click on cancel in the level settings window to end/abort the test.
If you have this fault... Within about 30seconds (but try to give it a minute), you may hear the beep become a distorted buzz or miss a beat altogether. If you do, you have a faulty card.
M-audio UK support are totally unwilling to admit the problem is theirs. However, if the s/pdif output channel fault can be heard over the monitor mixer, it MUST be occuring BEFORE it leaves the cards s/pdif output.
Any feedback from other users will be greatly appreciated by me, and don't hesistate to ask any questions about this or if you run into problems carrying out the test.
Postscript.
I should point out that I've been using an M-audio Audiophile2496 card in the same computer, pci slot and the same driver version and that does not have this problem.
Cheers
Jim
The Problem.
The Test.
Playback/Recording.
Postscript.
Cheers
Jim
