Hey Guys - Don't panic you've still got jobs !
I've got that thing and I like it a lot.
It'll read the wave file you input and supply you with a spectral view (8192 points) of the average and peak across the audio spectrum.
Next you get a cursor that'll allow you to push the EQ around however you like just like a parametric EQ that lets you select anywhere from the full spectrum down to about 1/10 octave. Any changes contribute to the new shape of the spectrum and you can make multiple chages till you get the shape you want.
Which parts of the curve should you 'push' around ? Well you can import a reference wave or use one of the references supplied. Heck you can even import pink noise if you want to simply apply a good old general +3dB/octave tilt to your wave.
One place where I might part with the creators is that you have to listen to what you're pushing around (I think the marketing hype might lead you to believe you only have to watch a picture). Last night I re-balanced an old cassette of a live show and when I lifted the bottom end to match a reference curve guess what - yep all the low end garbage came up too ! He He so it's like anything else if there is some good content at the frequency you're raising you can balance it - otherwise you've got to augment (I used
Baxxpander to add some bass and it worked very well
http://www.kvr-vst.com/get/491.html ).
It will show you resonances or valleys in your spectrum in a way similiar to an averaging or infinite peak spectrum analyzer. It doesn't work in real-time yet and it's not a plug in yet.
I think the support is very good also.
I like it as it gives me a different view of my audio along with different ideas and techniques.
Very Cool !
kylen
