If your primary concern is eeking out "pure volume", then you're wasting your money on something as good sounding as the Manley, because any advantage it would give you will be wiped out by your quest for the Holy RMS.sbcgroup2 said:When ISN'T it about pure volume?
sbcgroup2 said:Should I stick with my Waves Ultramaximizer or invest in a nice tube stereo mastering compressor (like a Manley, etc) for mastering to a final CD?
It would be so much easier just to keep it in the digital domain.
Thanks!
I hear where you're coming from Glenn, but I normally have a much easier time getting to "STUN" levels using hardware... Not that I enjoy it...SouthSIDE Glen said:If your primary concern is eeking out "pure volume", then you're wasting your money on something as good sounding as the Manley, because any advantage it would give you will be wiped out by your quest for the Holy RMS.
G.
Yeah, that's a very good point, John. I agree.Massive Master said:I hear where you're coming from Glenn, but I normally have a much easier time getting to "STUN" levels using hardware... Not that I enjoy it...
Remember, the ultramaximizer is not a typical compressor, it's a peak limiter - very different uses...sbcgroup2 said:Should I stick with my Waves Ultramaximizer or invest in a nice tube stereo mastering compressor (like a Manley, etc) for mastering to a final CD?
No offense, but this is precisely the type of thinking that has driven audio quality down for over a decade. Don't worry about what's easier, worry about what sounds better...It would be so much easier just to keep it in the digital domain.
Thanks!
SouthSIDE Glen said:Yeah, that's a very good point, John. I agree.
It just seems like such a shame to spend all that money and get all that quality, just to use it to flatten a mix into a pancake. It's kind like going out and buying a brand new Volvo for it's excellent crash handling and safety engineering so that it can be used in a demolition derby .
But like Golden said, if you got the bucks to burn, then more volu...er...power to you.
G.
sbcgroup2 said:Tell me more!
What do you use as your analog medium?
sbcgroup2 said:I like the idea of applying effects like reverb, delays and eq on the computer since I can constantly adjust the levels w/o having to constantly re-record the track.
Thanks!
MCI2424 said:A top of the line analog deck will not outperform a top of the line digital pro rig, it is just that most people cannot afford a pro rig so the low cost stuff takes a bashing.
Massive Master said:Heh... I spent most of the last couple days doing nothing but taking "top of the line" digital recordings and running them to 1/2" tape and pulling the signal directly off the repro heads (a.k.a. "Layback" for those in Rio Linda) to give it some breath.
And I don't track much anymore - But whenever I can, if I can do the same at the tracking level (record to tape and pull off the repro heads into the DAW), I'm all over it.
"Better" or "worse" is subjective to some extent - But "different" can't be ignored. Some prefer one over the other. I prefer both.
The days of being able to choose not only between Ampex, BASF, Maxell, and many other brands of open-reel tape, let alone different formulations of each brand, are long over, the last time I checked. Last time I looked, for most folks the choices are Quantigy, Quantigy or Quantigy.SonicAlbert said:The other factor is the quality of the tape formulations themselves, which I've heard has declined. In other words, it's becoming harder and harder to get really excellent quality tape. I don't use tape myself, but I've heard the bitching about the quality.
