Farview
Most hardware compressors are not digital, so it isn't a matter of signal processing power. Hardware units are purly analog, so they have much more headroom (generally) than the digital convertors. So it is much harder to clip it. Hardware compressors can be used to lower the peaks before the signal gets to the convertors.Toki987 said:Farview, You seem to be pretty sharp on this stuff. I have a question for you, please. Maybe I can make this sound simply sensible...
If a hardware compressor has its on processor inside to manipulate the stream of data, and a software compressor uses a virtual processor loaned to it by the OS to manipulate the data stream, are they not equal in capacity providing the computer has a processor fast enough and the algorithims used by the virtual processor are written well enough?
I guess the question could go to anyone else that knows, as well.
mic->preamp->hardware compressor->convertors->software
mic->preamp->convertors->software->plugin compressor
It's not that a software compressor does anything different it is just that it is in a different place in the signal chain.
