D
djclueveli
does hard pan mean pan 100% left and 100% right?
That's what I would take it to mean. Anything else is generally just called panned, as in 50%, or 9 oclock, or something.djclueveli said:does hard pan mean pan 100% left and 100% right?
LemonTree said:reverse the phase. That's the problem with copying the track. If you retrack another take it won't happen. I take it your problem is a spill over from FordVan's thread, the delay should cancel out the phase.
djclueveli said:when i copy a track and make 2 of them, then hard pan and change the cents by -12 and +12, i get phase problems when i hard pan each one or when i dont hard pan each one. how would i be able to fix this
That's how I did mine. Is this correct?NL5 said:Also, how are you changing the pitch? In real-time?
Dogman said:That's how I did mine. Is this correct?
djclueveli said:but when i put a 25ms delay on both of the tracks, the vocals are off beat.
djclueveli said:yea i am confused lol. i thought i only have two tracks when i'm done. how is there 3? how do i put the delay on the track without it comin in late cause if i put a 25 ms delay, then the vocal track will come 25ms late into the song. can you help me out with this. Is the delay a "Delay" plugin or "Reverb" plugin. Cause i'm using Acids "Simple Delay" plugin for this. If you use a different delay plugin can u let me know which one and tell me exactly how to set the numbers on the delay plugin cause it will help me out alot. And how do i end up with 3 vocal tracks if i copy the vocal track and hard pan it. That is only 2 tracks.
djclueveli said:yea you're explanation was better than FV cause i didn't know you should have 3 vocal tracks. that was the problem right there. Everything is sound good, but what pitch shifter plugin do u use cause the acid pitch shifter cause flange and the cakewalf one makes the works skip a little bit.
