Hi,
First my relevant PC stats:
PIII 700
ASUS CUBX (440BX chipset, 100/66 fsb, runs up to UDMA 66)
384 PC100 RAM
~35GB IBM Deskstar 75GXP, 7200 RPM (home drive)
~30GB WD Caviar, 5400 RPM (alternate drive)
As you can see I use the older, but revered BX chipset. The motherboard is not upgradeable to current standards, but I think the data rates should be fine. What I was concerned with was the alternate drive, the 5400 rpm WD. Given all of the information above, do you think all my hardware and the WD drive will be up to spec for recording usage?
I'll be using the Omni package w/Delta 66. I also plan on formatting the C drive soon as the computer has not had one in about a year. I will keep all that is stored on the D drive there though, and I do defrag both drives quite often. I want to reformat C and reinstall the o/s and other programs as computers get a but sluggish over time. Will the Wester Digital be fast enough for recording or do I need to use the IBM?
Thanks!
PIII 700
384 PC100 RAM
Thanks!
