H E L P is NEEDED
  • Thread starter Thread starter Drum-Addick
D
Drum-Addick
I currently use Fruity Loops 5 and I was trying to hook up my Dr.Groove dr-202 to the program so I could use it instead of using my typing keyboard on Fruity Loops. I believe that I need to install the Dr. Groove's drivers, but I cant find that software anywhere. I have tried to connect my midi connectors (two in the back of the drum machine, and the sound card into the back of the computer/ the sound card is a midi adapter with a sound card side and a joystick side) to the computer and then link my midi controller on Fruity Loops but nothing is working, can anyonye help me?
First you'll need to explain more detailed what you want to do. Do you want to use the sounds that are in your dr. groove in fruity loops, are do you only want to only use your dr. groove to trigger samples that are already within fuity loops?
The first can only be done with an audio connection (not with midi). The second can only be done with a midi connection (midi is data, you are sending the note on data to the computer that takes that signal and uses it to output an audio sample).
ok
Well i want to be able to use my dr-groove to trigger the samples.
Then you'll need midi only. The way you describe is correct for connecting your dr. groove to a computer. You probably have a midi setting wrong somewhere. You probably won't need drivers. Look for midi setup somewhere in fruity.
