Guitar Tracks 2
  • Thread starter Thread starter G.A. Donis
G
G.A. Donis
I've noticed that when I import a drum loop from Drag & Drop Drummer at a given tempo and then play that loop in GT2 with the same tempo and the metronome on, the loop does not sync with the metronome clicks. Is this a latency problem or is something else happening?
...Well, I don't use GT, but SONAR, in Cakewalk generaly, you wanna set the Clock source to Audio to make perfect sync with loops... (Options --> Projects --> Clock Source)...
Is the Drag and Drop Drummer audio-based or Midi-based?
If it's audio, then you have not set the tempo correctly... ;)
Hi...
All the loops in the GT 2 library are recorded at 100 BPM and are not "acidized"...If you import one of these loops at anything but a tempo of 100 they will either play out of synch, out of pitch or just sound altogether distorted. The upgrade to GT Pro fixed this, as its loop library can be imported at project tempo. Hope this helps. If you need any more help feel free to ask. I have both progs and are fairly familiar with them.
darwinsdoggy said:
Hi...
When I set up the tempo in GT2 to 100bpm and put in a loop from Drag&Drop Drummer that is 100 bpm and play the loop with GT2's metronome set to play during playback, the click from the metronome and the beat of the loop do not coincide. When I get some time, I'll play around with some of the settings to see if I have something set up wrong.
