guitar amp sim.-how to add EQ?
  • Thread starter Thread starter dontouch
D
dontouch
When using a guitar amp sim., do you place it BEFORE the EQ and compression or AFTER?
Is it a good idea to re-amp the dry DI guitar through a room mic(TLM67), and then blend that w/ the sim. version?
How should I EQ the 67? Or is it necessary?
the 67 was placed in a stairwell...15' from the amp.
Before. It's supposed to be the "source sound", so I'd say sim first, everything else afterwards.
Try it and see
EQ as needed. There is no secret recipe.
Well, the amp's tone controls come before its power stage and speaker, so it wouldn't be totally inconsistent to put eq before the amp sim, but I would probably use the eq in the sim if it has any. If you record an actual amp you might apply eq to the recorded signal so using some after also makes sense. It just depends. I might use some guitar pedal style compression before and/or studio style compression after. Again it just depends.
I'd use the EQ on the amp sim, then if you need more precise EQ, put it after everything. Just as you would if recording a real amp.
To simulate the most natural recording, you'll probably want the sim before the EQ then the compression. Make sure to spend some time with the sim and the EQ section of the "amp". Pretty much treat the EQ and comp as you would in the mixing stage.
As for recording the room, that sounds like it could work pretty well. Most sims have a room feature, so that might be better and easier.
EQing the room track is gonna be your job. I don't know how that'll work and how it'll fit in your mix.
dirt pedal sims (if separate plug)--->amp sim--->speaker sim (again if separate plugin)--->mutiband compressor (if wanted)--->parametric eq
this is just my opinion...
You could place an EQ first thing, even B-4 the sim, if you like. You could then also place an EQ AFTER the sim. Plus, there are EQ's in the sim (the tone knobs). Then, there are the tone knobs on the guitar which, in reality, are nothing more than high pass/low pass filters. So, in this example, you now have 4 stages of EQ. If you can keep it all straight, more power to you. If you need to simplify things, start cutting ur number of EQ's. Even with no EQ inserts, you'll still have at least a minimum of 2 stages of EQ: the guitar tone controls and the controls in the amp simulator. So you do the math and choose whichever makes you happiest.
As far as then NATURALLY miking the amp and ocmbining the two sounds, totally go for it. This can achieve a much more balanced and fuller sound. My advice in this instance is to record the amp in a totally dead space and THEN apply the space manually with a reverb on the track. This simply will give you much, MUCH more creative freedom during the session. (read on...)
Say, later in the session, you want to mix down and when you recorded the amp you recorded it in the middle of your living room and even turned on some reverb from the amp. This reverb, along with the acoustics of your room, is now printed to the track, along with your amp sound. Unless you 100% for sure, absolutely know this is what you want (my point being that being that sure is highly unlikely) then you now have a track that is printed eternally with a lot of ambience also.
I personally would also record the amp sound dry or as dry as I felt comfortable and, if I needed more space/natural ambience, add it with reverb or delays. This way, when you experiment during mixdown, you're options are completely open: recording with room ambience and/or amplifier reverb kind of cuts a lot of those options out when the track is printed while recording.
When you mix the two sounds together, if both are dry, once again, you will have many more options. Also, who's to say you don't end up dropping one sound or the other altogether. If you drop the DI in the mix and end up using only the miked amp, you will want a dry amp sound to play with. Again, these are simply opinions and there are no rules. Only artistic interpretation and variance from one engineer's technique to another. What one finds taboo may be the others crem de la creme.
