antichef
pornk rock
I mentioned in an earlier thread that I purchased two of the Edcor ribbon mic transformers - the RMX1 - and one of them arrived dead (I put the other one in an ACM-2 and made a thread about that). I let the Edcor folks know, and they immediately shipped a replacement (*nice*!). It arrived, and I got to work on the TnC ACM-3 from the group buy. The new one works fine.
For before/after samples, I figured out a ghetto re-amping technique (which I'll describe in a thread in the guitar section), and played the same short chord progression through a small 1960's practice amp - this allowed for pretty much identical conditions for the two samples (each 24/96 wav about 6 megs):
before: http://recursor.net/reamp/ACM3-stockTranny.wav
after: http://recursor.net/reamp/ACM3-edcor.wav
(signal path: reamp signal -> ~1965 Epi 101 EL84 amp -> ACM3 -> 5' cable -> Black Lion Audio modded MOTU traveler at +20 gain -> mac/Logic Express)
in retrospect, I maybe should have tried something more subtle, but since this is my most likely application for the mic, I figured it would be a good idea. As before, the RMX1 has a lower output, but I think a better sound.
and since reamping is so darn easy, I made bunch of bonus tracks -- placement was the same or similar (3" back from the middle of the cone), depending on the shape of the mic. I left everything else the same, including the gain on the preamp. I tried picking a bunch of mics that you might use for the same application - ribbons and dynamics.
the ACM-2 with the edcor tranny: http://recursor.net/reamp/ACM2-edcor.wav
a Nady RSM4, stock: http://recursor.net/reamp/NadyRSM4.wav
the lovely and talented ACM-4, stock (for now):http://recursor.net/reamp/ACM4-stockTranny.wav
um, SM-57: http://recursor.net/reamp/sm57.wav
and therefore, the Audix I5: http://recursor.net/reamp/i5.wav
and further, the Shure Beta 57a: http://recursor.net/reamp/Beta57a.wav
and the Shure SM-7b: http://recursor.net/reamp/sm7b.wav
and an old EV RE-10: http://recursor.net/reamp/EV-RE10.wav
I've got some Lundahl transformers on the way, but I think I'm done modding that ACM-3 - I've about DIYed it to death, having soldered/unsoldered everything about 8 times. I heated up one of the XLR pins from the inside so much that it drooped down in the plastic and sticks out further than the others. I guess I could replace that whole component, but it still works for now.
