G
Gilliland
The phase problem is much weirder than I thought. When I'm close to the microphone, it sounds out of phase on the label side, but farther back, the out-of-phase sound swaps sides to the non-labeled side. Really bizarre. Must have to do with the headbasket design.
*scratches head*
How are you judging the polarity of the mic? If you're trying to do it "live" - by listening in headphones while speaking/singing into the mic - you will find your efforts futile. The problem is that your voice is reaching your ears through acoustic methods at the same time that it's reaching your ears through headphones. The resulting mix of phases will give you a completely unreliable idea of what is coming from the mic.
The only way to get a meaningful result is to record your voice (or other source) using the mic, then listen to it in playback.
I apologize if you're already doing this, but many people have been fooled by this kind of error. And it would tend to yield exactly the kind of observations that you've provided.
