P
PINCARTO
can some one explain how to ground the dp24, or more to the point, where do I run the grounding wire to, thanks,
Has the dp24 go an earth pin on the power lead? If it hasn't it does not need to be mains earthed as it will be a double insulated system.
I ask again, what is the actual question here? If there is a problem with the power point earth call an electrician.
Alan
