J
johnnymegabyte
Just moved into a house, and setting up all my gear in the basement, which is fully carpetted.
Yamaha 4 track (used as 6 channel mixer)
Inputs: 1=mic, 2=guitar gear, 3+4=Roland synth, 5+6=PC using a ground loop isolator
Outputs: 1. headphones, 2. Monitor Out ( to my stereo system ), 3. L+R Out --- to Line IN of PC
When first set it up, it was without PC and everything seemed OK
Then, I add PC into the loop, I noticed a hum, which sounded like a grounding problem.
I start playing with all the channel levels to see where it might be coming from. Not this
Then, I unplug the connection between Yamaha and stereo, and now it's gone.
The input on the receiver is CD. I am using my DVD player with TOSLink for playing CD's.
Now, I think that the cable input might be causing the ground related hum.
I have a VCR with the cable coming into it, connected to the TV, which feeds back to the receiver.
Soooooooooooo, is there a way to eliminate this hum ?
Can I ground the cable input in some way ?
Could it be the connection from Yamaha to PC Line IN ?
Any ideas ?
Any ideas ?
