JAPOV
Progressively Challenged...
I live in an old house that's not well grounded... Any advice?
Ground the house - Two Prong receptors are a death trap - also they are a noise conductor - of course rewiring might not be in the budget - so you could just wire you Music Room - isolated from the rest of the house with it's own circuit breakers - I would do a minimum of 80 amps - 4 wall Circuits - and then a 15 amp circuit for the lights - there is no other way IMO - BTW your buzz noise is caused by the Guitar and Amp not Grounding.I live in an old house that's not well grounded... Any advice?
I quite agree. I know nothing about US electrical "code" so NOTHING I say should be taken as 'legal'! But, I cannot see any reason why OP cannot simply change all his 2 pin outlets for 3pin and install some sort of grounding system?Ground the house - Two Prong receptors are a death trap - also they are a noise conductor - of course rewiring might not be in the budget - so you could just wire you Music Room - isolated from the rest of the house with it's own circuit breakers - I would do a minimum of 80 amps - 4 wall Circuits - and then a 15 amp circuit for the lights - there is no other way IMO - BTW your buzz noise is caused by the Guitar and Amp not Grounding.
