hemmick reef
Well I actually have 'The Brick' preamp and I was wondering what sort of difference I would hear to my vocals through a channel strip like the oneQ, using a Groove Tubes 67 valve mic and an SM57?
Thanks
Thanks
I have a UAD-1 card which can do most of the eq & compression but I am wondering if the channel strip will have a different quality more suited to tracking?
The Brick has some asymmetrical distortion when you get the level up around 2 or 3 o'clock, but this helps give it a nice fat sound. The D.I. alone is worth the price.
The OneQ is a wonderful coloring box. It's a unique sound shaping tool.
Excellent analysis, caveat is knowing how to use these tools, you can wreck a picture easily by using too many colors
the brick is a one trick pony. keep that in mind. Condenser mics and bass DI are the tricks. Not a lot of gain for dynamics.
That's 2 tricks.
The brick can also anchor hot air balloons.
Ahhh, now you're entering into "slippery slope" territory. An "improvement"? "Bigger"? "Smoother"?Thanks for the replies - got a bit lost on the last few posts though
So will it sound different enough to make an improvement - bigger smoother vocal sound?
