I like it. I switched to flatwound on my cheap-o bass just so I'd stop making little skweesky sounds. Your new bass looks a lot more badasser than my cheap-o.
That's a nice lookin' bass. 1 question tho, is their much of a sound diffrence in the longer neck V'S regular length. As you can guess I don't play a stringed instrument.
That's why I started using flatwounds too except I didn't want to go thru the torment of actually lifting my fingers all the way off the strings every time.
'Sides, I like the sound of em.
Badasser......heh heh...
Good question...and I dunno.
I can't hear a difference. When I first played it, I thought the fretboard felt different but just chalked it up to being used to my guitar again. Not really sure what the purpose of the longer neck is tbh.
long stick go boom.
It makes a bigger difference at lower tunings, but generally extended scales give you higher tension and a more bell-like attack and piano-like clarity at a given tuning and string gauge. On higher-tuned notes this can be undesirable (27" guitars can sound a bit sharp and biting in the higher registers, which may or may not work for you), but on the low end it is a bit clearer.
