Gorunding Issues
  • Thread starter Thread starter jtlaurie
J
jtlaurie
I have a question. I have a Fender Japanese Made Telecaster (about 3-4 years old) and a Fender Princeton Chorus Amp. For some reason I'm having grounding issues. I've done a couple tests and it seems like it may be the guitar. I put hands over the strings to see if it would stop the hum and it didn't work. I also checked the different pickup settings on my guitar and there's still a hum. I even had my guitar jack fixed a couple months ago. Any idea of what's wrong and what I can do to fix it? I'm recording on Sunday. Thanks!
I have almost the same setup. I found that I have terrible hum when the selector switch is in the 1, 3, 5 positions.. 2 & 4 are a lot quieter..
That don't help you but great question...
jtlaurie, is it two single coils?
It sounds like if the grounding and/or shielding on your guitar is not very good.
here is some info on grounding and shielding.
http://www.stewmac.com/freeinfo/i-4000/4000_09.html
This is the wiring diagram for your Tele.
take the pickguard off and confirm everything os OK.
Sounds like the bridge ground wire isn't properly connected. Follow the diagram from the grounding of the jack. A wire should go to the metal bridge. This will make the hum stop when you touch the strings.
Scott, you might already know this but the reason positions 2 and 4 are quieter is because they are humbucking positions.
Position 2 uses neck and middle together and position 4 uses middle and bridge together.
Positions 1, 3 and 4 uses their respective single coil pickups alone.
I took what he said as a joke. ya know......its a single coil......its gonna hum.......
I am working on making a homemade deal so I can take my hand off the guitar and not have the massive feedback. Its gonna be fancier than a damn wrist braclet:D
guitarnuts.com has useful grounding info.
Check out "Quieting the beast's cousin".
It's worthwhile to ground/shield the whole guitar.
You live in Chicago . . . call Andy's Music on Belmont and Western and rent a sweet guitar and amp for the weekend. You can usually describe to them the kind of tone you're after, and they'll hook you up fairly inexpensively.
BTW -- did you try a bunch of different cords?
